StarTech.com DisplayPort DVI Video Adapter Converter
£16.27
47 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Simple to use, small form factor converter makes DisplayPort backwards compatible with your DVI-D display
  • No installation software or drivers required providing a simple plug and play solution
  • Stock Status: In Stock
Product codes
Connect your DVI monitor to a DisplayPort equipped computer. The StarTech.com DP2DVIADAP DisplayPort DVI adapter lets you connect a DVI-D display to a DisplayPort video source (e.g. DisplayPort video cards, etc.), eliminating the expense of having to upgrade to a DisplayPort enabled display while providing a hassle-free connection to any DisplayPort video card/signal source.
The DVI/DisplayPort adapter supports display resolutions up to 1920x1200, allowing you to take full advantage of single link DVI capability.
DP2DVIADAP is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
Product Description StarTech.com DisplayPort DVI Video Adapter Converter - DisplayPort adapter
Type DisplayPort adapter - single link
Connector DisplayPort - male
Connector (Second End) DVI-D - female
Compliant Standards FCC, RoHS
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com DisplayPo...
£16.27
