StarTech.com DisplayPort to DVI Active Adapter
£26.79
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Active DisplayPort converter for DisplayPort video cards not capable of outputting DP++ (multi-mode) signals
  • Simple to use, small form-factor converter makes DisplayPort backward compatible with your DVI-D single link display
  • Latching DisplayPort connector ensures a solid connection
  • Length: 20cm
  • Stock Status: In Stock
Product codes
The DP2DVIS DisplayPort to DVI Active Single Link adapter lets you connect your DisplayPort video source (desktop PC, laptop, etc.) to a DVI-D monitor, projector or display, including televisions and Apple Cinema Display HD, eliminating the expense of having to upgrade to a DisplayPort-capable monitor. Unlike passive adapters, this DP to DVI converter offers an active conversion for use with any DisplayPort output - ideal for graphics cards that are not capable of outputting multi-mode DP++ signals (e.g. ATI Eyefinity). Supporting resolutions up to 1920x1200, this compact device provides a simple solution for converting DisplayPort output for compatibility with existing DVI monitors, televisions or projectors.
Product Description StarTech.com DisplayPort to DVI Adapter - Active Conversion - 1920x1200 - DP to DVI Single Link Converter for DVI-D Display (DP2DVIS) - DisplayPort adapter - 20 cm
Type DisplayPort adapter
Features HDCP compliant
Length 20 cm
Connector DisplayPort - male
Connector (Second End) DVI-D - female
Compliant Standards FCC, RoHS
Colour Black
Designed For P/N: DK30C2DAGPD, DKWG30DPHPD, DKWG30DPHPDU, MST30C2DPPD, SP123DP, TB32DP2T, TB3CDK2DP, TB3CDK2DPUE, TB3CDOCKDP, TB3DK2DHV, TB3DK2DHVUE, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE, TB3DKM2DP
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com DisplayPo...
£26.79
