StarTech.com DisplayPort to HDMI Adapter with USB Audio
Key features
  • DisplayPort video with USB audio pass-through to a single HDMI cable
  • Supports uncompressed, 2-channel audio such as LPCM
  • USB-powered - no external power source required
  • Supports HDTV resolutions up to 1080p (1920 x 1080)
  • Easy to use cable, no software/drivers required
  • Provides a simple solution that minimizes clutter by combining separate cables (audio and video) into one
  • Allows you to send video and accompanying audio
  • Requires no software/drivers for operation, providing a Plug-and-Play solution that will have you up and running in seconds
Product codes
The DP2HDMIUSBA DisplayPort to HDMI Adapter with USB Audio is a cost-effective solution that lets you connect an HDMI capable HDTV to a device with DisplayPort output, avoiding the expense of upgrading the TV for compatibility.
Featuring a compact design, the DisplayPort to HDMI converter/adapter requires minimal space and draws power through the USB connection, so that no bulky external power supply or outlet is required. Simply plug the integrated USB and DisplayPort connectors into your PC or Mac, and use the desired length of HDMI cable to connect to your television/monitor. The 2-channel analog audio signal passes through the HDMI connection, delivering the video and accompanying audio signals using a single HDMI cable.
DP2HDMIUSBA is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
StarTech.com DisplayPort to HDMI Adapter with USB Audio - video converter - black
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort input - 20 pin DisplayPort , 1 x HDMI output - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A
5.6 cm x 1.5 cm
Enclosure Colour
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com DisplayPo...
