StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F
£13.11
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Simple, small form factor converter makes a DisplayPort video card backward compatible with your HDMI display
  • Easy to use, no software or drivers required
  • Stock Status: In Stock
Product codes
The DP2HDMIADAP DisplayPort to HDMI Adapter provides a DisplayPort male and HDMI female connector, allowing you to keep your existing (HDMI) display while using a DisplayPort video card/source.
Supporting display resolutions of up to 1920 x 1200(computer)/1080p(HDTV), this cost-effective solution maintains the incredible graphical performance offered by DisplayPort, while eliminating the cost of having to upgrade your HDMI capable display to a display with built-in DisplayPort support.
DP2HDMIADAP is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
Backed by a StarTech.com 1 year warranty and free lifetime technical support.
StarTech Advantage
  • Supports PC resolutions up to 1920x1200 and HDTV resolutions up to 1080p
  • Easy to use adapter, no software required
Applications
  • The DisplayPort to HDMI adapter allows for an easy and hassle free connection to any HDMI display
Product Description StarTech.com DisplayPort to HDMI Adapter – 1920x1200 – DP (M) to HDMI (F) Converter for Your Computer Monitor or Display (DP2HDMIADAP) - video adapter - DisplayPort / HDMI
Cable Video adapter - DisplayPort / HDMI
Connector DisplayPort - male
Connector (Second End) HDMI - female
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com DisplayPo...
£13.11
