StarTech.com DisplayPort to VGA Video Adapter Converter
£27.19
30 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Simple to use, small form factor converter makes DisplayPort backwards compatible with your VGA display
  • Stock Status: In Stock
Product codes
The StarTech.com DP2VGA DisplayPort to VGA adapter lets you connect a VGA computer monitor to a DisplayPort video card or other DisplayPort source, eliminating the expense of upgrading the monitor for compatibility. The DP to VGA adapter uses an integrated chip to provide an active digital to analog conversion.
Product Description StarTech.com DisplayPort to VGA Adapter - 1920x1200 - Active DP to VGA Video Converter - Plug and Play DP to VGA Connector (DP2VGA) - display adapter - 25 cm
Type Display adapter
Features Latched
Length 25 cm
Connector DisplayPort - male
Connector (Second End) HD-15 (VGA) - female
Compliant Standards FCC
Designed For P/N: DK30C2DAGPD, DPPNLFM3, DPPNLFM3PW, MST14DP123DP, MSTDP122DP, MSTDP123DP, MSTMDP122DP, MSTMDP123DP, SP123DP, SV231DPU, TB32DP2T, TB3DK2DPM2, TB3DOCK2DPPD, TB3DOCK2DPPU
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com DisplayPo...
£27.19
