StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA...
StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket
£9.20
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Type: Storage bay adapter
  • Stock Status: In Stock
Product codes
Mount two 2.5in SATA SSDs/HDDs into a single 3.5in drive bay. The BRACKET25X2 Dual hard drive mounting bracket kit enables you to maximize the internal mounting space of your computer, by installing two 2.5in SATA hard drives (HDD) or solid state drives (SSD) into a single 3.5in mounting bay. The bracket can be used with IDE drives using the 2.5in to 3.5in IDE Hard Drive cable adapter (IDE4044).
For a hassle-free installation, the hard drive mounting kit includes all required data and power cabling for both SATA drives.
The BRACKET25X2 features solid steel construction.
Product Description StarTech.com Dual 2.5" SATA Hard Drive to 3.5" Bay Mounting Bracket - storage bay adapter
Device Type Storage bay adapter
Colour Steel
Supported Form Factor 3.5" to 2.5"
Expansion Bays 2 x internal - 2.5"
Compatible Bay 1 3.5"
Dimensions (WxDxH) 10.2 cm x 11.6 cm x 2.2 cm
Weight 150 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Dual 2.5"...
£9.20
