StarTech.com Dual 4K TB3 Dock - M.2 - SD
£349.29
12 in stock
Delivery:
Standard: 1-3 working days
Key features
  • LOCALIZED HIGH-PERFORMANCE STORAGE: Thunderbolt 3 dock has a PCIe NVMe M.2 SSD bay to store/back up files, SD/SDHC/SDXC 4.0 UHS-II card slot & USB-C 3.1 Gen 2 10Gbps port to connect an external drive
  • DESIGNED FOR CONTENT CREATORS: The Thunderbolt 3 Dock features dual monitor 4K 60Hz or single 5K 60Hz via DisplayPort & downstream TB3/USB-C port, SD, 1x USB-C & 2x USB-A Hub, Gigabit Ethernet & audio
  • 85W POWER DELIVERY: Thunderbolt 3 docking station with charging to power & charge workstation laptops like MacBook Pro 13/15/16, HP EliteBook, Lenovo ThinkPad, Dell XPS using macOS and Windows
  • FLEXIBLE THUNDERBOLT 3 PORT: Thunderbolt 3 docking station's downstream TB3 port supports 15W & three modes of operation: a second display, daisy chain TB3 peripherals, or connects USB-C accessories
  • EASY TO SET UP & USE: This Thunderbolt 3 port replicator features automatic driver setup; includes TB3 host cable (40Gbps) and front facing ports - USB-A & USB-C BC 1.2 Fast Charge, SD 4.0, & Audio
  • Type: Docking Stations
  • Device Screen Size: [N/A]
  • Colour: Black
  • Stock Status: In Stock
Product codes
This compact Thunderbolt 3 dock is built for productivity, transforming your Thunderbolt 3 MacBook Pro or Windows laptop into a dual-4K workstation with up to 40Gbps of throughput. The high- performance dock features a PCIe M.2 SSD slot for enhanced data storage, three USB ports, an SD card reader, a Gigabit Ethernet port, a downstream Thunderbolt 3 port for daisy-chaining, plus 85W Power Delivery.
Great for Ultra HD tasks, the dual-4K docking station supports 4K resolution on two monitors: 1x DisplayPort and 1x Thunderbolt 3 USB-C display (4096 x 2160p @60Hz) (USB-C to DP cable or USB-C video adapter may be required).
Connect to a single 5K monitor at 60Hz.
The Thunderbolt 3 dock's built-in PCIe M.2 SSD enclosure supports transfer speeds up to 1500MB/s with the addition of a PCIe M.2 SSD for ultra-fast data access, enhanced storage, and application buffering and caching.
Transfer photos or videos from your SD cards to your Thunderbolt 3 laptop. The dock's SD slot supports SD 4.0 and UHS-II with transfer speeds up to 270MB/s.
Connect peripherals with three USB ports - one USB-C port (10G) with up to 3A charging and two USB-A ports (5G) with Fast-Charge and Sync.
The GbE port (with PXE Boot and WoL support) provides reliable wired network access.
Using a single cable, the Thunderbolt 3 dock provides up to 85W of Power Delivery charging.
Product Description StarTech.com Thunderbolt 3 Dock - Dual Monitor 4K 60Hz Docking Station w/ DisplayPort - PCIe M.2 NVMe SSD Enclosure, SD 4.0, USB, 85W PD - docking station - DP, Thunderbolt
Product Type Docking station
Docking Interface Thunderbolt 3
Video Interfaces DP, Thunderbolt
Localisation Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
Networking Gigabit Ethernet
Power Power adapter
Designed For P/N: ARMBARDUO, ARMBARDUOV, ARMDUAL, ARMDUAL30, ARMDUALV, ARMSLIMDUO
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Dual 4K T...
£349.29
