StarTech.com Dual Bay 5.25" Trayless Hot Swap Mobile Rac...
StarTech.com Dual Bay 5.25" Trayless Hot Swap Mobile Rack for SATA HDD/SSD
£38.07
Delivery:
Standard: 1-3 working days
  • Type: Storage bay adapter
  • Stock Status: In Stock
Product codes
Easily connect and hot swap dual 2.5" and 3.5" SATA/SAS hard drives from a 5.25" bay. The HSB2535SATBK Removable 2-drive backplane lets you quickly install and hot-swap drives from the front of your computer, by turning a 5.25" bay into a hot-swappable SATA/SAS interface for you to connect a 3.5" SATA hard drive (HDD) and/or a 2.5" SATA hard drive or solid state drive (SSD).
The hard drive bay interfaces with SATA/SAS, offering two trayless hard drive bays and can be mounted into any 5.25" front bay, to provide a hot-swappable mobile rack. The bays feature ejection levers which allow drives to be installed and removed quickly from the computer system, providing a convenient way to create backups that can then be removed for safekeeping, archiving, or external portable access.
For added versatility the backplane provides support for both SATA and SAS interfaces, an ideal accommodation for enterprise system integration. Plus, to help prevent drive failure, the bay provides excellent heat dissipation with a built-in fan and slotted aluminum enclosure.
Product Description StarTech.com Dual Bay 5.25" Trayless Hot Swap Mobile Rack Backplane for 2.5" and 3.5" SATA/SAS HDD or SSD with Fan (HSB2535SATBK) - storage bay adapter - SATA 6Gb/s / SAS 6Gb/s
Device Type Storage bay adapter
Expansion Bays 1 x hot-swap - 3.5" , 1 x hot-swap - 2.5" x 1/8H
Compatible Bay 1 5.25" x 1/2H
Interface SATA 6Gb/s / SAS 6Gb/s
Dimensions (WxDxH) 18.26 cm x 14.8 cm x 4.2 cm
Weight 520 g
Designed For P/N: 25SAT35HDD, PEXMSATA3422, PEXMSATA343
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Dual Bay...
£38.07
