StarTech.com Dual-Bay SATA HDD/SSD Dock
Key features
  • Access two 2.5/3.5” SATA hard drives (HDD) or solid state drives (SSD) simultaneously and hot swap drives in and out
  • USB 3.0 with data transfer speeds of up to 5Gbps
  • Convenient top-loading design with independent drive doors
Product codes
Use this SATA hard drive docking station to gain quick access to two of your 2.5" or 3.5" SATA III SSDs/HDDs. This dual-bay SATA HDD/SSD docking station lets you dock and swap drives from your desktop or laptop computer simultaneously, using a single USB port. It supports two 2.5/3.5" SATA hard drives or solid-state drives.
The dual-bay docking station supports USB 3.0, also known as USB 3.1 Gen 1, providing fast data transfer speeds of up to 5Gbps. It also supports UASP, for enhanced performance.
Ideal for IT professionals, such as system administrators and technicians, the hard drive dock enables you to complete device-management tasks more efficiently, such as disk image duplication, data recovery, backing up and archiving hard drives, and transferring content between drives and devices. It also enhances your workflow, by providing quick access to your hard drives, with the ability to easily swap drives in and out as needed.
Designed for easy drive access, the hard drive dock enhances your workflow, by providing quick access to two hard drives, with the ability to easily swap drives in and out as needed. The hard drive dock features a convenient top-loading design with independent drive doors that make it easy to add or remove drives.
The dual-bay SATA HDD/SSD docking station is OS independent, with no drivers or software installation required, for easy setup.
Product Description StarTech.com Dual Bay SATA HDD Docking Station for 2.5 3.5in HDD - USB 3.0 - HDD docking station - SATA 6Gb/s - USB 3.0
Device Type HDD docking station - external
Bays 2
Bus Type USB 3.0
Colour Black
Expansion Bays 2 x hot-swap - 2.5" / 3.5" shared
Hard Drive Form Factor Compatibility 2.5", 3.5"
Interface SATA 6Gb/s
Data Transfer Rate 6 Gbit/s
Supported Devices Hard drive, solid state drive
Product Material Plastic, aluminium
Power Source Included AC adapter
Power AC 100 - 240 V
Dimensions (WxDxH) 13 cm x 11.4 cm x 6.2 cm
Weight 730 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Dual-Bay...
