StarTech.com Dual Monitor Stand - Articulating - For Monitors...
StarTech.com Dual Monitor Stand - Articulating - For Monitors up to 32"
£171.67
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Save space by mounting two monitors up to 32" (up to 17.6 lb./8 kg per display) on a single base
  • Dual articulating arms provide a wide range of motion
  • Freestanding monitor stand with adjustable height along the 16.7" (42.4 cm) pole
Product codes
Customize your workstation, and free up space, with this dual-monitor stand. Mount two monitors on the dual articulating monitor arms, and adjust your displays for optimum viewing with a wide range of motion. The free-standing base gives you flexibility in placing your setup within your workspace.
Work more efficiently with a dual-monitor setup. The horizontal dual-monitor stand lets you mount two VESA mount (75x75, 100x100 mm) monitors, up to 32", with a maximum weight capacity of up to 17.6 lb./8 kg per display.
Mounting your displays on a dual-monitor stand above the desk surface enables you to adjust your display height, position and viewing angles for an ergonomic workspace. The swiveling arms provide maximum viewing flexibility, letting you work in comfort.
It's easy to customize your setup, placing your monitors at the ideal height. Simply adjust the display height along the 16.7" (42.4 cm) pole. You can align your monitors perfectly with the micro-adjustment feature.
Extend the dual articulating arms up to 18.4" (46.8 cm) to position your monitors in the ideal position. Tilt your monitors +90/-40 degrees and swivel +90/-90 degrees for ideal viewing. Rotate your displays for portrait or landscape viewing.
Neatly route your cables, keeping them organized and out of view, with the cable-management channels.
Product Description StarTech.com Dual Monitor Stand, Ergonomic Desktop Monitor Stand for up to 32" VESA Displays, Free-Standing Articulating Universal Computer Monitor Mount, Adjustable Height, Silver - Easy & Quick Assembly - stand - for 2 monitors - black, silver
Product Type Stand - desktop
Dimensions (WxDxH) 92.6 cm x 11.6 cm x 55 cm
Tilt -40° to 90°
Pan -90° to 90°
Rotation -180° to 180°
Adjustments Height
Weight 4.8 kg
Recommended Use 2 monitors
Recommended Display Size 32"
VESA Mounting Interface 100 x 100 mm, 75 x 75 mm
Max Load Weight 16 kg
Material Plastic, aluminium, steel
Colour Black, silver
Manufacturer Warranty 5-year warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£171.67
