StarTech.com Dual Port ExpressCard Gigabit Laptop Ethernet NI...
StarTech.com Dual Port ExpressCard Gigabit Laptop Ethernet NIC Network Adapter Card
£131.49
Delivery:
Product codes
The EC2000S 2-port Gigabit ExpressCard Ethernet Adapter adds 2 10/100/1000Mbps Ethernet ports to an ExpressCard-enabled laptop, or small form factor system, enabling you to connect to two separate physical networks simultaneously with dedicated bandwidth, or providing full dedicated bandwidth to virtual machines.
Supporting features such as NDIS5 checksum and large send offload for lower CPU utilization, Wake-on-LAN (WOL) and Remote Wake-up power management, jumbo frames and VLAN tagging, this ExpressCard Ethernet Adapter is ready to handle a wide variety of scenarios.
With a 34mm ExpressCard form factor, this compact and portable Gigabit Ethernet Adapter will fit in any ExpressCard-enabled system.
Product Description StarTech.com Dual Port ExpressCard Gigabit Laptop Ethernet NIC Network Adapter Card - network adapter
Device Type Network adapter
Form Factor Plug-in module
Interface (Bus) Type ExpressCard/34
Ports Gigabit Ethernet x 2
Dimensions (WxDxH) 3.4 cm x 11.6 cm x 2.1 cm
Weight 150 g
Cabling Type Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
Data Link Protocol 10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate 1 Gbps
Network / Transport Protocol TCP/IP, UDP/IP
Processor 1 x Realtek Semiconductor RTL8111E
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x
System Requirements Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Apple MacOS X 10.6 - 10.9, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Dual Port...
£131.49
