StarTech.com Dual Port PCI Express Gigabit Ethernet PCIe Netw...
StarTech.com Dual Port PCI Express Gigabit Ethernet PCIe Network Card Adapter - PoE/PSE
£122.95
43 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Provides versatile network connections with support for advanced features such as Jumbo Frames and VLAN tagging, as well as Wake-On-LAN and Auto MDIX
  • Reduces cable clutter and makes it easier to install devices in remote locations that are powered by the the PSE network card, with up to 25.5W of power delivery as well as a solid network link over a single cable connection
  • Suitable for installation in full profile or small form factor computer cases using the included half-height/low profile bracket, adding two network connection ports using a single PCI Express slot
  • Wired / Wireless: Wired
  • Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
  • Form Factor: Plug-in card
  • Compatibility: PC
  • Type: Network adapter
Product codes
Add two Power-over-Ethernet Gigabit Ports to a PCI Express-enabled Computer. The ST2000PEXPSE Dual Port PoE NIC provides two 10/100/1000 Mbps PoE RJ45 ports that can provide up to 25.5W of power each, combining a network data connection and power on a single cable, for less clutter and convenient installations in remote locations.
This full/low profile Gigabit server adapter supports the IEEE 802.3at (Type 1 and 2) standard for a Power Sourcing Equipment (PSE) device, and can deliver 48V DC power to compliant Powered Devices (PD). This eliminates the need for a separate power source and cable for remote networked devices such as IP cameras, IP phones and wireless access points.
Suitable for any PCI Express-enabled client, server or workstation, this versatile PoE network adapter supports features such as Jumbo Frames, VLAN tagging and Wake on LAN (WOL).
Product Description StarTech.com Dual Port PCI Express Gigabit Ethernet PCIe Network Card Adapter - PoE/PSE - network adapter
Device Type Network adapter
Form Factor Plug-in card
Interface (Bus) Type PCI Express x1
Ports Gigabit Ethernet x 2
Dimensions (WxDxH) 6.8 cm x 19.5 cm x 1.9 cm
Weight 150 g
Cabling Type Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
Data Link Protocol 10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate 1 Gbps
Processor RTL8111E - Realtek Semiconductor
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3at
System Requirements Microsoft Windows XP 64-bit Edition, Microsoft Windows 98SE/2000/ME/XP, SuSE Linux Kernel 2.4.x, Microsoft Windows Vista, Microsoft Windows Vista (64-bit versions), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Dual Port...
£122.95
