StarTech.com Dual Sit Stand Desk/Wall Mount
£393.20
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Save space with this wall-mounted sit-stand desk, supporting: dual monitors, bar-code scanner, keyboard, wrist rest and mouse in one combo system
  • Supports two monitors up to 24" (with weight capacity of 17.6 lb./8 kg)
  • Compact sit-stand desk folds back to the wall, keyboard tray folds up to 90°, saving space when not in use
  • Stock Status: In Stock
Product codes
Easily convert your dual monitor workstation into a standing desk for greater comfort and productivity. This wall-mounted sit-stand desk for dual monitors is perfect for areas that don't have enough space for a traditional sit-stand desk. Its compact, wall-mounted design combines a dual-monitor arm and a keyboard tray, with easy height adjustments that let you alternate between sitting and standing without disrupting your workflow.
Adjust your working position in one smooth motion. Simply lift the work surface up to 17.2" (436 mm), to elevate your monitor, keyboard and mouse. The monitor mount has a separate height adjustment of up to 4.9" (124 mm) along the column.
This sit-stand monitor arm supports two monitors up to 24" (with weight capacity of 17.6 lb./8 kg). Adjust your monitor for ideal viewing, with -15° to +15° swivel and 0° to 30° tilt, or rotate your monitors up to 360° for portrait or landscape orientation.
The sit-stand desk folds back to the wall, and the keyboard tray folds up to 90°, saving space when not in use. You can move the swing arm left or right (from -90° to 90°) and lower or raise the arm (from -30° to 65°) to make maximum use of your space.
The monitor arm offers plenty of work space, with a large keyboard tray (17.68 x 8.15"/ 449 x 207 mm) and a slide-out tray (8.5 x 8.4" / 217 x 213 mm) that holds your mouse, on the left or right.
Product Description StarTech.com Sit Stand Dual Monitor Arm - For 2 x 24in Monitors - Height Adjustable - VESA Dual Monitor Stand - Sit Stand Workstation (WALLSTS2) - mounting kit
Product Type Mounting kit
Mounting Components Wall plate, column, 2 crossbars, keyboard tray, monitor arm, 2 x VESA monitor mounts, crossbar mount
Dimensions (WxDxH) 119.4 cm x 95.8 cm x 92.6 cm
Tilt 0° to 30°
Pan -90° to 90°
Rotation 360°
Adjustments Height
Weight 10.3 kg
Recommended Use 2 monitors
Recommended Display Size 24"
VESA Mounting Interface 100 x 100 mm, 75 x 75 mm
Material Plastic, aluminium, steel
Colour Black
Image Colour Disclaimer The displayed product image may be a different colour
Package Content 4 x washers, 4 x concrete anchors, 4 x M6x12 screws, hex key (5mm), wrench, hex key (2.5mm), hex key (6mm), wall plate, adhesive strip, socket driver, M8x20 screw, 3 x M6x10 screws, VESA monitor mount, 4 x mounting screws, 2 x M6x8 screws, 8 x M4x10 screws
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Dual Sit...
£393.20
