StarTech.com Dual USB C Dock - Drive Bay
£184.89
13 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Easily connect dual DisplayPort monitors right out of the box, with no display drivers to set up
  • Add data storage and backup with an internal 2.5” SATA SSD/HDD drive bay
  • Connect your USB devices with 3x USB 3.0 (Type-A) ports including 1x Fast-Charge
Product codes
Create an MST based, dual-video workstation that expands your storage using an open 2.5" SSD/HDD bay and powers your laptop with USB Type C (5Gbps). This dual-monitor USB-C docking station adds valuable data storage and backup to your Windows laptop, and makes it easy to create a multi-monitor workstation through support for DP Alt Mode and DisplayPort Multi-Stream Transport (MST).
The USB-C dock provides a versatile way to connect to two DisplayPort monitors, a wired network and three USB 3.0 devices, while housing a 2.5" HDD or SSD for added storage or backup, all through a single USB-C cable. Plus, with Power Delivery support, you can power and charge your laptop as you work.
Featuring a built-in 2.5" SATA SSD/HDD drive bay, this docking station gives you the added advantage of external data storage and backup, reducing the number of devices on your desktop. You can consolidate your peripherals, including external storage, with just one connection to your laptop. This reduces clutter in your workspace and simplifies workflow, making it easier to perform routine tasks like data offloads.
The 2.5" drive bay supports SATA I, II, and III. It's ideal for creative professionals, IT executives, engineers, business executives and other professionals requiring high-performance functionality and external storage and backup, with Windows Backup, macOS Time Machine or other backup software. And, if you want to add further external storage, the dock has three USB 3.0 ports available.
This premium laptop dock capitalizes on the full potential of USB Type-C, which simultaneously transfers power, video, and data.
The docking station supports USB Power Delivery, providing up to 60 watts of power. This means you can power and charge your laptop while it's docked, through its USB-C port, and cut clutter at your workstation. Plus, you don't need to carry or remember an extra power adapter when you're traveling to or from the office.
This dual-monitor docking station replicates the high performance of a full-size workstation, with DP Alt Mode and MST support providing single, mirror and extended display mode functionality. The USB-C docking station supports 4K Ultra HD resolution (providing the connected DisplayPort display supports it).
With this versatile dock, you can connect: 2x DisplayPort display at 1920 x 1200 resolution (60Hz); 1x DisplayPort display at 3840 x 2160 resolution (30Hz).
Note: Multi-display and dual-display configurations are only supported in Windows operating systems that support MST.
Ensure your laptop's drivers, firmware, and operating system are up to date prior to using the docking station.
Video output capabilities are dependent on the video card and hardware specification of your connected laptop. Certain video cards have limited MST support, while some monitors will also limit the available resolution.
Not all USB-C ports support the full functionality of the USB Type-C standard. Ensure that your laptop USB-C port supports DP alt mode, as well as USB Power Delivery.
Not all Thunderbolt 3 USB-C ports support the full functionality of the Thunderbolt 3 standard. Ensure that your laptop Thunderbolt 3 port supports USB Power Delivery.
macOS does not support MST.
Product Description StarTech.com Dual-Monitor USB-C Dock - Windows - MST - 2.5" SATA SSD / HDD - docking station
Product Type Docking station
Docking Interface USB-C
Dimensions (WxDxH) 9 cm x 21 cm x 2.8 cm
Weight 133 g
Colour Black & silver
Localisation Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
Networking Gigabit Ethernet
Power Power adapter 60 Watt AC 120/230 V
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Dual USB...
£184.89
