StarTech.com DVI-D to VGA Active Adapter Converter Cable – 19...
StarTech.com DVI-D to VGA Active Adapter Converter Cable – 1920x1200
£32.62
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Save time: quick and hassle-free DVI-D to VGA setup
  • Save space: compact design with no need for an external power adapter ensures a portable solution with a minimal footprint
  • Type: A/V
  • Length: 24.8m
Product codes
Connect a DVI-D equipped Laptop or Desktop Computer to your VGA Display, or Projector. The DVI2VGAE active DVI-D to VGA adapter lets you connect a digital DVI output from your desktop or laptop computer onto a VGA monitor or projector, saving the cost of upgrading to a DVI-D compatible display.
Providing a simple way to output user-generated content such as presentations and work documents, the DVI-D to VGA converter can also work to increase your productivity by extending your computer's desktop onto to a secondary monitor, doubling available workspace.
This portable adapter works to convert a standard powered DVI bus to VGA, without an external power source. For low-powered DVI ports, a USB cable is included that can power the device from any USB power source.
With support for resolutions up to 1920x1200 (WUXGA), this active adapter offers a comprehensive solution for connecting a High-Definition VGA display to a DVI-D video source.
Product Description StarTech.com DVI-D to VGA Active Adapter Converter Cable - 1080p - DVI to VGA Converter box (DVI2VGAE) - video adapter - 24.8 m
Type Video adapter
Features Active adapter, 1920 x 1200 (WUXGA) support
Length 24.8 m
Connectors 24+1 pin digital DVI - male , 5 pin Micro-USB Type B (power only) - female
Connectors (Second End) 15 pin HD D-Sub (HD-15) - female
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£32.62
