StarTech.com DVI DDC EDID Ghosting Emulator with EDID Copy
£67.83
Select:
Delivery:
Standard: 1-3 working days
Key features
  • EDID Copy feature saves time by making sure your display works the way you want it
  • Simple rotary switch enables you to quickly emulate the EDID settings that you want
  • Sturdy steel enclosure provides durability for harsh environments
Product codes
Copy or emulate Extended Display Identification (EDID) data for optimal display settings. The VSEDIDDVI DVI EDID Emulator enables you to capture and retain Extended Display Identification Data from a monitor, which can then be connected to the video signal source (video extender, KVM switch, etc.) to pass the EDID information and ensure the proper video settings are maintained.
EDID information contains important display settings such as maximum image size, color characteristics, factory pre-set timings, frequency range limits, etc., and since most video extender systems don't offer EDID communication between the source and remote display, the DVI EDID Emulator is a perfect workaround for ensuring the optimum signal is provided to the display to help prolong the life of your displays.
StarTech.com DVI DDC EDID Ghosting Emulator with EDID Copy - EDID reader / writer - DVI
Interface Type
DVI
5.2 cm x 8 cm x 2.2 cm
123 g
Digital Video Capture Resolution
1280 x 720, 1600 x 1200, 1024 x 768, 1280 x 1024, 1920 x 1440, 1920 x 1080, 2048 x 1152, 2560 x 1440, 2560 x 1600, 1920 x 1200, 1440 x 900, 1680 x 1050, 1600 x 900
Double Duration Circuit (DDC) technology
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com DVI DDC E...
£67.83
