StarTech.com DVI-I to DVI-D Dual Link Video Cable Adapter F/M
£8.24
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Connect a DVI-I cable to a DVI-D port. StarTech.com's DVIIDVIDFM DVI-I to DVI-D adapter features a male DVI-D (dual link) connector and a DVI-I female connector, essentially turning a female DVI-D (dual link) connector into a female DVI-I connector.
The adapter allows DVI-I cables to be used in Digital only (DVI-D) connections between PC and monitor, eliminating the cost of having to buy a (DVI-D) cable to connect a DVI (digital) display.
Product Description StarTech.com DVI-I to DVI-D Dual Link Video Cable Adapter F/M - DVI adapter - dual link - DVI-I (F) to DVI-D (M) - gray - DVIIDVIDFM - DVI adapter
Type DVI adapter - dual link
Connector DVI-I - female
Connector (Second End) DVI-D - male
Compliant Standards RoHS
Colour Grey
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com DVI-I to...
£8.24
