StarTech.com DVI to HDMI Video Converter with Audio
£65.70
12 in stock
Delivery:
Standard: 1-3 working days
Key features
  • DVI-D video with audio pass-through to a single HDMI cable
  • Supports HD 1080p (1920 x 1080) resolution
  • Supports 2-channel RCA audio
  • Compact design
  • Rugged metal enclosure
  • RCA audio pass-through allows DVI video and accompanying audio to be sent over a single HDMI cable
  • Requires no software/drivers for operation, providing a Plug-and-Play solution that will have you up and running in seconds
  • Compact, rugged metal enclosure functions even in harsh environments, while conserving space
  • Stock Status: In Stock
Product codes
The DVI2HDMIA DVI to HDMI Converter/Adapter lets you connect a DVI-D source with the accompanying RCA audio signal to an HDMI monitor or HDTV, with support for full HD 1080p (1920x1080) resolution.
A cost-effective alternative to upgrading equipment for compatibility, this small form factor adapter provides a plug-and-play solution for connecting your Mac, PC or home theater device with DVI (digital) output to your television or HDMI monitor. The RCA stereo audio connections integrate the audio signal directly into the HDMI output, so that a single cable can be run to your destination device.
Product Description StarTech.com DVI to HDMI Video Converter with Audio - Video converter - DVI - HDMI - black - DVI2HDMIA - video converter - black
Device Type Video converter
Max Resolution 1920 x 1080
Interfaces 1 x DVI-I input - 24+5 pin combined DVI , 1 x audio line-in - RCA x 2 , 1 x HDMI output - 19 pin HDMI Type A
Dimensions (WxDxH) 2.6 cm x 8.8 cm x 6.8 cm
Enclosure Colour Black
Manufacturer Warranty 1-year warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com DVI to HD...
£65.70
