StarTech.com DVI to VGA Cable Adapter - Black - F/M
£6.81
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Cost-effective solution for connecting an analog Flat Panel Display to a PC or Mac computer with VGA output
  • Backed by StarTech.com lifetime warranty
  • Stock Status: In Stock
Product codes
Use your DVI-I Display with a VGA video card. The DVIVGAFMBK DVI-I to VGA Display Adapter (F/M) is used to convert a DVI male connector to a VGA male connector. The DVI to VGA adapter is constructed of high quality materials, to ensure dependability.
This product is intended for connections between DVI-I and VGA devices. If your device uses a DVI-D connector, please refer StarTech.com's DVI to VGA Converter DVI2VGACON.
Product Description StarTech.com DVI-I to VGA Cable Adapter - Black - F / M - DVI I to VGA Adapter for Your VGA Monitor or Display (DVIVGAFMBK) - VGA adapter
Type VGA adapter
Connector DVI-I - female
Connector (Second End) HD-15 (VGA) - male
Colour Black
Designed For P/N: BNDDKT30CAHV, USB31GEVG, USB3SMDOCKHV
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com DVI to VG...
£6.81
