StarTech.com DVI to VGA Cable Adapter - F/M
£7.59
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Connect your DVI-I Display to a VGA video card. The DVIVGAFM DVI to VGA Cable Adapter converts a DVI male connector to a VGA male connector, allowing you to connect devices with VGA output to a DVI input port.
The DVI to VGA cable adapter eliminates the expense of having to upgrade a VGA video source for the sake of compatibility with a newer DVI capable display.
This product is intended for connections between DVI-I and VGA devices. If your device uses a DVI-D connector, please refer to StarTech.com's DVI to VGA Converter DVI2VGACON.
Product Description StarTech.com DVI to VGA Cable Adapter - F/M - DVI to VGA connector - DVI to VGA Converter - DVI to VGA Adapter (DVIVGAFM) - VGA adapter
Type VGA adapter
Connector DVI-I - female
Connector (Second End) HD-15 (VGA) - male
Compliant Standards FCC, RoHS
Colour Beige
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com DVI to VG...
£7.59
