StarTech.com DVI to VGA Cable Adapter - M/F
£5.84
More than 50 in stock
Delivery:
Standard: 1-3 working days
Product codes
The DVIVGAMF DVI-I to VGA Display Adapter (M/F) is used to convert a DVI Male connector to a VGA female connector. The DVI to VGA adapter is constructed of high quality materials to ensure dependability.
This product is intended for connections between DVI-I and VGA devices. If your device uses a DVI-D connector, please refer to StarTech.com's DVI to VGA Converter DVI2VGACON.
Product Description StarTech.com DVI to VGA Cable Adapter - M/F - VGA adapter
Type VGA adapter
Connector DVI-I - male
Connector (Second End) HD-15 (VGA) - female
Colour Beige
Designed For P/N: IP2DVI, SV421DVI, SV221DVI
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com DVI to VG...
£5.84
