StarTech.com DVI to VGA Cable Adapter M/F - 10 pack
£23.49
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Connect your VGA Display to a DVI-I source. The DVIVGAMF10PK 10-pack of DVI-I to VGA Adapters offers a cost-effective option when you have multiple DVI-enabled computers to connect to VGA monitors.
At a lower cost per unit, these DVI to VGA adapters convert DVI male connectors to VGA female connectors - a perfect solution for schools, and other organizations to connect DVI-I desktop or laptop computers to VGA monitors or projectors.
The adapters are constructed of high-quality materials to ensure dependability.
This product is intended for connections between DVI-I and VGA devices. If your devices use a DVI-D connector, please refer to StarTech.com's DVI to VGA Converter (DVI2VGACON).
Product Description StarTech.com DVI to VGA Cable Adapter M/F - 10 pack - VGA adapter
Type VGA adapter
Packaged Quantity 10 (specifications are for single item)
Features Molded, thumbscrews
Connector HD-15 (VGA) - female
Connector (Second End) DVI-I - male
Compliant Standards RoHS
Colour Beige
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com DVI to VG...
£23.49
