StarTech.com eSATAp / eSATA or USB 3.0 External 2.5in SATA II...
StarTech.com eSATAp / eSATA or USB 3.0 External 2.5in SATA III 6 Gbps Hard Drive Enclosure with UASP
£34.29
44 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Versatile connectivity options, through either USB or eSATA/eSATAp
  • Maximum portability with a small footprint, and support for eSATAp (no external power adapter required)
  • Save time, with file transfers up to 70% faster than traditional USB 3.0 when used with a UASP-supported host
  • Type: Storage enclosure
  • HD Size: 2.5"
  • Stock Status: In Stock
Product codes
Turn a 2.5" SATA III HDD / SSD into an external hard drive that can connect to your computer through either eSATAp at 6 Gbps, or USB 3.0 with UASP at 5 Gbps. The S251SMU33EP USB 3.0 / eSATAp drive enclosure turns a 2.5in SATA hard drive (HDD) or solid state drive (SSD) into an external portable hard drive that can connect to any USB or eSATA-enabled computer system.
For fast performance and efficient data transfers when connected through eSATA, the enclosure supports full SATA III transfer speeds - up to 6 Gbps. For universal compatibility, the S251SMU33EP can be connected through USB 3.0 with transfer speeds up 5 Gbps plus support for UASP, which delivers performance up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller to utilize the full potential of your SATA III hard drives.
Designed for maximum portability, the S251SMU33EP doesn't require an external power adapter when connected to an eSATAp (USB + eSATA combo) host port.
The 2.5in enclosure supports the fastest drive technologies including SATA III (6 Gbps), hybrid drives and solid state drives (SSD), saving you time by ensuring you're getting the most out of your drive performance.
To ensure compatibility with your computer system, the S251SMU33EP supports all of the leading operating systems, including: Microsoft Windows, Apple OSX, Linux, and Google Chrome OS.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP-enabled StarTech.com Enclosure, and a SATA III solid state drive.
Product Description StarTech.com eSATAp/eSATA External Hard Drive Enclosure - 2.5" SATA III Hard Drive Enclosure - Portable HDD/SDD w/ UASP (S251SMU33EP) - storage enclosure - SATA 6Gb/s - eSATA 6Gb/s, USB 3.0
Device Type Storage enclosure - external
Bus Type eSATA 6Gb/s, USB 3.0
Colour Silver
Expansion Bays 1 x internal - 2.5"
Hard Drive Form Factor Compatibility 2.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Supported Devices Hard drive
Max Storage Devices Qty 1
Product Material Aluminium / plastic
Power Source USB bus
Dimensions (WxDxH) 7.7 cm x 12.5 cm x 0.95 cm
Weight 96 g
Designed For P/N: HB30C1A1CPD, HB30C3AGEPD, HB30C3APD, HB30C3APDW, HB30C4AB, HB30C4ABW, HB30C4AFPD, HB30C4AFS, SATDUP11IMG, ST43004UA, ST4300MINI, ST73007UA, TB2DOCK4K2DP, USB3SMDOCK4K, USB3VDOCKD
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com eSATAp /...
£34.29
