StarTech.com Expansion Slot Rear Exhaust Cooling Fan with LP4...
StarTech.com Expansion Slot Rear Exhaust Cooling Fan with LP4 Connector
£7.84
21 in stock
Delivery:
Standard: 1-3 working days
  • Type: Case Fan
  • Stock Status: In Stock
Product codes
The StarTech.com PC case exhaust fan is an add-in cooling fan designed to fit in the PCI or ISA expansion slots of any computer. It is used to exhaust warm air out, preventing problems due to overheating components. The exhaust fan inlet faces adjacent PCI or AGP cards and makes a great video card cooler for hot running 3D accelerator cards like the Voodoo, TNT2, GeForce256 and others. A quiet running brushless DC motor coupled with a high efficiency blade design is capable of moving 36 CFM (cubic feet per minute) of air. Power is supplied to the fan using a standard LP4 (hard drive power connector) pass through plug.
Product Description StarTech.com Expansion Slot Rear Exhaust Cooling Fan with LP4 Connector system fan kit
Product Type System fan kit
Noise Level 32 dB
Dimensions (WxDxH) 12 cm x 11 cm
Weight 0.2 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Expansion...
£7.84
