We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The 10051-ST is an Extreme Networks 10051 compatible fiber transceiver module that has been designed, programmed and tested to work with Extreme Networks brand switches and routers. It delivers dependable 1 GbE connectivity over fiber cable, for 1000Base-SX compliant networks, with a maximum distance of up to 550 m (1804 ft).
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
Product Description | StarTech.com Extreme Networks 10051 Compatible SFP Module, 1000BASE-SX, 1GbE Multimode Fiber MMF Optic Transceiver, 1GE Gigabit Ethernet SFP, LC 550m, 850nm, DDM, Mini GBIC - Lifetime Warranty (10051-ST) - SFP (mini-GBIC) transceiver module - GigE | Device Type | SFP (mini-GBIC) transceiver module - LC multi-mode | Form Factor | Plug-in module | Cabling Type | 1000Base-SX | Data Transfer Rate | 1 Gbps | Optical Wave Length | 850 nm | Data Link Protocol | GigE | Max Transfer Distance | 550 m | OEM Manufacturer Equivalent Part Number | Extreme Networks 10051 | Dimensions (WxDxH) | 5.56 cm x 1.37 cm x 1.25 cm | Weight | 16 g | Manufacturer Warranty | Limited lifetime warranty | Designed For | Summit 24e3; Alpine 3802; Extreme Networks GM-16T3, GM-16X3 |
General | |
Device Type | SFP (mini-GBIC) transceiver module |
Networking | |
Connectivity Technology | Wired |
Features | Full duplex capability, Digital Diagnostics Monitoring (DDM) |
Expansion / Connectivity | |
Interfaces | 1 x Ethernet 1000Base-SX - LC multi-mode female x 2 |
Miscellaneous | |
MTBF | 629,953,711 hours |
Compliant Standards | FCC, MSA |
Dimensions & Weight | |
Width | 5.56 cm |
Depth | 1.37 cm |
Height | 1.25 cm |
Weight | 16 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 9 cm |
Shipping Depth | 11.5 cm |
Shipping Height | 3.1 cm |
Shipping Weight | 50 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Compatibility Information | |
Designed For | Summit 24e3 , Alpine 3802 , Extreme Networks GM-16T3, GM-16X3 |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
