StarTech.com Extreme Networks 10056H SFP Module - Lifetime Wa...
StarTech.com Extreme Networks 10056H SFP Module - Lifetime Warranty - 100
£44.46
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 100% Compatibility with Extreme Networks 10056H guaranteed
  • StarTech.com SFP modules are backed by a lifetime warranty
  • Pairs with 10057H-ST
  • Stock Status: In Stock
Product codes
The 10056H-ST is an Extreme Networks 10056H compatible downstream fiber SFP transceiver which pairs with StarTech.com's 10057H-ST. They are designed, programmed and tested to work with 1000Base-BX-D compatible Extreme Networks switches and routers. The SFP transceiver module supports a maximum distance of up to 10 km (6.2 mi) and delivers dependable 1 GbE connectivity over fiber cabling.
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP Cables, providing the convenience and reliability you need to ensure dependable network performance.
Product Description StarTech.com Extreme Networks 10056H Compatible SFP Module - 1000BASE-BX-D - 10 GbE Gigabit Ethernet BiDi Fiber (SMF) - SFP (mini-GBIC) transceiver module - GigE
Device Type SFP (mini-GBIC) transceiver module - LC single-mode
Form Factor Plug-in module
Cabling Type 1000Base-BX-D
Data Transfer Rate 1 Gbps
Optical Wave Length 1310 (RX) / 1490 (TX) nm
Data Link Protocol GigE
Max Transfer Distance 10 km
OEM Manufacturer Equivalent Part Number Extreme Networks 10056H
Dimensions (WxDxH) 5.66 cm x 1.37 cm x 1.25 cm
Weight 20 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Extreme N...
£44.46
