StarTech.com Extreme Networks 10065 Comp SFP Copper Module -...
StarTech.com Extreme Networks 10065 Comp SFP Copper Module - 1000Base-T
£42.73
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 100% Compatibility with Extreme Networks 10065 guaranteed
  • StarTech.com SFP modules are backed by a lifetime warranty
  • Uses a cost-effective cabling alternative to fiber-optic set ups
  • Stock Status: In Stock
Product codes
The 10065-ST is an Extreme Networks 10065 compatible copper transceiver module that has been designed, programmed and tested to work with Extreme Networks brand switches and routers. It delivers dependable 1 GbE connectivity over copper cable, for 1000Base-T compliant networks, with a maximum distance of up to 100 m (328 ft).
This SFP copper module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
Product Description StarTech.com Extreme Networks 10065 Compatible SFP Module - SFP (mini-GBIC) transceiver module - GigE
Device Type SFP (mini-GBIC) transceiver module - RJ-45
Form Factor Plug-in module
Cabling Type 10Base-T, 100Base-TX, 1000Base-T
Data Transfer Rate 1 Gbps
Data Link Protocol GigE
Max Transfer Distance 100 m
OEM Manufacturer Equivalent Part Number Extreme Networks 10065
Dimensions (WxDxH) 6.8 cm x 1.37 cm x 1.38 cm
Weight 15 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Extreme N...
£42.73
