StarTech.com Fiber Optical Cable 10m MPO / MTP
£335.25
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Interface between different networking devices at varying speeds
  • Optimize accessibility and install or remove connectors with one hand using the push-and-pull tabs
  • MTP connectors use Type A straight-through pinout
  • Length: 10m
  • Colour: Aqua
  • Stock Status: In Stock
Product codes
Terminate twelve fiber connections using a single 40 Gigabit network cable - designed for high-density fiber networks. This MPO/MTP fiber optic cable houses 12 fibers and lets you interface between different networking devices of varying speeds. For example, you can set up a one-to-one connection between two 40Gbps switches or servers. Alternatively, you can connect a 40Gbps switch and break out the 40Gbps into six duplex 10Gbps LC connections on a patch panel or network cassette, which then fans out to individual 10Gbps devices.
The MTP connector provides twelve times the density of an SC connector and saves circuit card and rack space. Plus, the push-and-pull tabs optimize accessibility by letting you install or remove the connectors with one hand without using additional tools.
The MTP to MTP cable is housed in a plenum-rated jacket and is ideal for in-wall installations, or anywhere CMP fire rating is required.
Each OM3 fiber cable has been individually tested for insertion loss and return loss. The full test report is included in each cable bag.
Product Description StarTech.com MTP Fiber Optic Cable - 30 ft / 10m - OM3 - 40Gb - Push / Pull Tab - Plenum - MPO / MTP Connector - Fiber Patch Cable (MPO12PL10M) - network cable - 10 m - aqua
Type Network cable - OM3
Technology Fibre optic
Type of Fibre Optics Multimode
Features Plenum
Length 10 m
Core / Cladding Diameter 50 / 125 micron
Connector MTP/MPO multi-mode - female - push/pull
Connector (Second End) MTP/MPO multi-mode - female - push/pull
Colour Aqua
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Fiber Opt...
£335.25
