StarTech.com Flat-Screen TV Ceiling Mount
£117.79
Delivery:
Standard: 1-3 working days
Key features
  • Save space by suspending your 32 to 75" flat-screen TV from the ceiling
  • Min-max pole length extension of 42" to 61" (1060 to 1560 mm)
  • Ceiling TV mount swivels +60 /-60 degrees to adjust to sloped or level ceilings
Product codes
Mount a flat-panel television to your ceiling with adjustable pole length, tilt and pan for easy viewing. Save space and mount your flat-screen television in the ideal viewing location, by suspending it from the ceiling. This robust steel ceiling mount supports VESA mount compatible TVs up to 70" in size. It's easy to adjust, so you can change the distance from the ceiling, and tilt or pan to create the optimal viewing angle.
The TV ceiling mount lets you mount your flat-panel LCD, LED or plasma TV in a prominent and comfortable viewing area while saving wall, desk and floor space. It's ideal for use in corporate boardrooms, hotel lobbies, restaurants, bars and meeting spaces. The heavy-duty TV ceiling mount works with 32 to 70" displays, and supports a weight capacity of up to 50 kg (110 lb.), making it compatible with a wide selection of TVs. To keep the cables out of view, you simply run the cables through the inside of the pole, exiting near the top.
With an adjustable pole length, the telescopic-style pole makes it easy to mount your display at the desired distance from the ceiling and works well with a range of ceiling heights. The robust steel pole can extend up to 1560 mm (61 in.) at maximum length, working well with most drop ceilings which are often found in commercial environments. The ceiling mount offers an extension range of 42 in. (1060 mm) to 61 in. (1560 mm) from the ceiling and features a height adjustment of 500 mm (19.7").
The LCD ceiling mount is designed to accommodate a wide variety of ceiling types. The ceiling mount swivels, so you can adjust the mount to work with virtually any type of ceiling for level viewing, including sloped ceilings (up to 60°), and pitched or horizontal (flat) ceilings. The extension pole also swivels + 180° / - 180° for optimum viewing.
You can adjust your flat-screen TV to create a comfortable viewing angle, by tilting it (up to -25°) down towards your audience for optimum visibility. The ceiling mount also features a 360° pan, which makes it easy to set up for viewing from any direction you choose.
The hook-and-mount design of the TV ceiling mount makes setup fast and easy. You simply attach the vertical brackets, with built-in hooks, to the back of your TV. Once the brackets are attached, you then hang your TV securely onto the ceiling mount. Cable management helps to keep cables out of view.
StarTech.com Ceiling TV Mount - 3.5' to 5' Pole - For 32" to 75" TVs - ceiling mount
Ceiling mount - ceiling mountable
Adjustable Height
0-50 cm
Tilt
0° to 25°
Rotation
360°
Adjustments
Height, pan, tilt, swivel
Recommended Use
Plasma / LCD / TV
Recommended Display Size
32"-75"
Flat Panel Mount Interface
200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 300 mm
Max Load Weight
50 kg
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Flat-Scre...
£117.79
