StarTech.com Flat-Screen TV Wall Mount
£43.89
42 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Save space with this flat screen wall mount for 32" to 75" TVs
  • Tilt your TV up or down (+15 to -15 degrees) for comfortable viewing
  • Heavy-duty steel TV wall mount supports up to 165 lb. (75 kg)
  • Type: Wall mount
  • Stock Status: In Stock
Product codes
Save space by mounting a flat-panel television to your wall, with easy tilt for ideal viewing. Maximize space while creating an impressive display with this heavy-duty wall mount for large flat-screen TVs or monitors. The flat-panel wall mount securely supports a VESA Mount compliant TV from 32" to 70", with easy-to-use tilt adjustment for comfortable viewing.
Mount your flat-screen TV in a location that's convenient for visitors, clients and employees, while saving valuable space. The wall mount is ideal for boardrooms, lobbies or other venues providing an impressive and secure way to display a large flat-panel TV or create digital signage. The robust wall mount supports a large 32" to 70" flat-screen TV weighing up to 165 lb. (75 kg).
The TV wall mount lets you angle your TV display toward your audience. With the tilt feature, you can mount your TV lower or higher than eye level and still view it comfortably. The tilt-adjusting knobs make it easy to adjust your TV to the ideal viewing angle.
The hook-and-mount design of the TV wall mount makes setup fast and easy. You simply attach the vertical brackets, with built-in hooks, to the back of your TV. Once the brackets are attached, you then hang your TV securely onto the wall mount. Cable management helps to keep cables out of view.
Product Description StarTech.com Flat Screen TV Wall Mount - Tilting - For 32 to 75" TV - Steel - wall mount
Product Type Wall mount - wall-mountable
Dimensions (WxDxH) 81 cm x 8.3 cm x 50 cm
Tilt -15° to 15°
Adjustments Tilt
Recommended Use LCD / plasma panel
Recommended Display Size 32"-75"
VESA Mounting Interface 200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 300 mm, 700 x 400 mm
Max Load Weight 75 kg
Colour Black
Package Content Allen key, 4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x30 screws, 4 x washers, 6 x flat washers, 6 x concrete anchors, 6 x 6.3x55 mm screws, 8 x spacers (long), 8 x spacers (short), 4 x M8x50 screws
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Flat-Scre...
£43.89
