StarTech.com Full Motion TV Mount - Steel
£57.51
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Save space with this flat-screen TV wall mount for 32" to 55" TVs (fits curved TVs, with compatible VESA mount)
  • Full-motion adjustment with arm extension up to 19.8" (503 mm)
  • The arm can tuck in closely to the wall, extending only 1.9" (49 mm)
  • Type: Wall mount
  • Stock Status: In Stock
Product codes
Free up space by mounting your flat-panel TV on a wall, with full-motion adjustment capability. Maximize space while creating an impressive display. This heavy-duty steel TV wall mount securely supports flat-screen TVs from 22" to 55". The arm extends easily to provide smooth, full-motion positioning for ideal viewing.
Mount your flat-screen TV in a location that's convenient for visitors, clients and employees. This TV wall mount is ideal for the lobby, boardroom or other venues, providing an impressive and secure way to display a flat-panel TV or mount digital signage. It also frees up valuable space. The TV wall mount supports most 22" to 55" (558.8 to 1397 mm) LED or LCD flat panel TVs weighing up to 77 lb. (35 kg).
The TV wall mount provides full-motion adjustment capability. The arm extends up to 19.8" (503 mm) from the wall to provide a wide range of movement and accommodate different screen positions and angles. The arm can also fold to tuck-in closely to the wall, providing a minimized profile, which enables you to position your display just 1.9" (49 mm) from the wall.
The TV wall mount swivels +90° / -90° to provide maximum viewing flexibility. The mount also tilts +2° / -12°, letting you angle your TV display toward your audience. With the tilt feature, you can mount your TV lower or higher than eye level and still view it comfortably.
The robust steel design safely and securely supports your flat-screen TV, to protect your investment. The TV wall mount also includes plastic brackets for cable management to keep cables neatly out of sight.
Product Description StarTech.com Full Motion TV Wall Mount - Articulating Arm - Supports 32" to 55" TVs/Displays - Flat Screen TV Wall Mount - Wall Mount TV Bracket -Steel (FPWARTB1M) - wall mount
Product Type Wall mount
Tilt -12° to 2°
Pan -90° to 90°
Adjustments Horizontal
Recommended Use TV
Recommended Display Size 32"-55"
VESA Mounting Interface 100 x 100 mm, 200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 300 x 200 mm, 200 x 100 mm, 300 x 300 mm, 100 x 150 mm
Max Load Weight 35 kg
Material Plastic, steel
Colour Black
Package Content 4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x30 screws, 8 x washers, 4 x M8x50 screws, 4 x bracket screws, 4 x nuts, 16 x spacers, 4 x VESA extension brackets, 4 x concrete screws, 4 x bracket washers, 4 x screws
Manufacturer Warranty 5-year warranty
Designed For P/N: HDMIPLATE
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Full Moti...
£57.51
