StarTech.com Full Motion TV Wall Mount
£314.62
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Save space by wall-mounting your 32" to 75" TV
  • Easy adjustment with full-motion articulating arms
  • Swivels +/-60° and tilts +/-15° for ideal viewing
  • Type: Wall mount
  • Stock Status: In Stock
Product codes
Strong and sleek, this full-motion TV wall mount lets you free up space by wall-mounting your 32" to 75" TV, and adjust it to the right viewing position with ease.
Once it's installed, the flat-screen TV wall mount is simple to adjust without using tools. You can extend the arms with ease to position your TV anywhere from 4.1" to 21.6" (105 to 550 mm) away from the wall. The TV mount swivels +/-60 degrees and tilts +/-15 degrees for optimum viewing.
This premium television wall mount beautifully combines form and function. Designed to provide an impressive appearance in every position, the premium black and silver design makes it ideal in a company lobby or hallway, information kiosk, or living space. With the arms extended, the protective covers provide a tidy, professional look. The cable-management channel inside the arms keeps cables neatly tucked away.
Engineered with steel and aluminum, the robust TV mount securely supports a TV with a maximum weight capacity of 187.4 lb. (85 kg).
Product Description StarTech.com Full Motion TV Wall Mount - Premium - Articulating Arms - For 32" to 75" TVs - Flat-Screen TV Wall Mount -Steel & Aluminum -Commercial Grade (FPWARPS) - wall mount
Product Type Wall mount
Dimensions (WxDxH) 87 cm x 55 cm x 52.4 cm
Tilt -15° to 15°
Swivel -60° to 60°
Adjustments Tilt, swivel
Recommended Use TV
Recommended Display Size 32"-75"
VESA Mounting Interface 200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 800 x 400 mm, 600 x 400 mm, 300 x 300 mm, 700 x 400 mm
Max Load Weight 85 kg
Material Plastic, aluminium, steel
Colour Black, silver
Package Content Hex key (6mm), TV mount, 2 x vertical brackets, 4 x flat washers, 2 x vertical bracket screws, 8 x concrete anchors, 8 x wall screws, 4 x M4 x 12 mm screws, 4 x M4 x 18 mm screws, 4 x M5 x 12 mm screws, 4 x M6 x 12 mm screws, 4 x M6 x 18 mm screws, 4 x M8x 12 mm screws, 4 x M8 x 18 mm screws
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Full Moti...
£314.62
