StarTech.com Gb Copper SFP HP 453154-B21 Compatible
£59.04
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • 100% compatibility with HP 453154-B21 guaranteed
  • StarTech.com SFP modules are backed by a lifetime warranty
  • Uses a cost-effective cabling alternative to fiber-optic set ups
  • Stock Status: In Stock
Product codes
Count on reliable and cost-effective Gigabit Ethernet connections with this RJ45 Mini-GBIC module. This HP compatible Gigabit Copper SFP is engineered by StarTech.com to deliver what you need most in your network connections: reliable performance. Built to exacting specifications and fully tested to ensure maximum performance, this high-quality SFP transceiver module can be installed into HP BladeSystem c-Class equipment that supports the HP 453154-B21 module, as well as other major brands of networking equipment.
This RJ45 1000Base-T SFP delivers Gigabit connectivity over a distance of up to 100 m (328 ft.). It provides a dependable and cost-effective way to add, replace or upgrade a copper Ethernet port on your networking equipment.
This Gigabit RJ45 SFP is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
This Gigabit Copper SFP is engineered to the highest quality standards and is 100% HP compatible, equivalent to the HP 453154-B21 SFP transceiver. The StarTech.com transceiver is configured and fully tested to ensure it works seamlessly with HP or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this SFP is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and convenient solution that's compatible with a multitude of multi- and single-port Gigabit Ethernet networking devices.
Ideal for use in HP BladeSystem c-Class and other compatible equipment, the SFP provides reliable performance, enabling you to expand your network to remote segments cost-effectively. The SFP supports auto-negotiation, a maximum distance of up to 100 m (328 ft.), and maximum data rates of up to 1000Mbps.
Product Description StarTech.com HPE 453154-B21 Compatible SFP Module - 1000BASE-T - 1GE Gigabit Ethernet SFP SFP to RJ45 Cat6/Cat5e - 100m - SFP (mini-GBIC) transceiver module - GigE
Device Type SFP (mini-GBIC) transceiver module - RJ-45
Form Factor Plug-in module
Cabling Type 1000Base-T
Data Transfer Rate 1 Gbps
Data Link Protocol GigE
Max Transfer Distance 100 m
OEM Manufacturer Equivalent Part Number HP 453154-B21
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Gb Copper...
£59.04
