StarTech.com Gb Fiber SFP - Cisco Compatible
£73.75
26 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 100% compatibility with Cisco GLC-LH-SMD guaranteed
  • StarTech.com SFP modules are backed by a lifetime warranty
  • Meets or exceeds OEM specifications and Multi-Source Agreement (MSA) industry standards
Product codes
Add reliable, cost-efficient Gigabit Ethernet connections over single-mode/multi-mode fiber with this Mini-GBIC module. This StarTech.com Gigabit fiber SFP is engineered to deliver reliable network connections. Built to exacting specifications and fully tested to ensure maximum performance, this high-quality fiber transceiver module can be installed into Cisco switches and routers that support the GLC-LH-SMD transceiver module, as well as other major brands of networking equipment.
It provides a dependable and cost-effective way to add, replace or upgrade the ports on your 1000Base-LX/LH networking equipment, and it's backed by a lifetime warranty.
This single-mode/multimode SFP transceiver is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
The SM/MM Gigabit SFP is engineered to the highest quality standards and is 100% Cisco compatible, equivalent to the Cisco GLC-LH-SMD SFP transceiver. The StarTech.com SFP transceiver is configured and fully tested to ensure it works seamlessly with Cisco or other major brands of networking equipment.
You can be assured that the use of StarTech.com SFP products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and cost-effective solution that's compatible with a multitude of Gigabit networking devices.
Ideal for use in switches, routers and other networking equipment, the SFP provides reliable performance, allowing you to expand your network to remote segments cost-effectively. The SFP supports Digital Diagnostics Monitoring and both single-mode (with maximum distance of 10 km or 6.2 mi.) and multimode (with a maximum distance of 550 m or 1804 ft.). It provides maximum data rates of up to 1.25Gbps.
You can count on GLCLHSMDST for reliable performance.
StarTech.com Cisco GLC-LH-SMD Compatible SFP Module - Lifetime Warranty - SFP (mini-GBIC) transceiver module - GigE
SFP (mini-GBIC) transceiver module - LC
Plug-in module
Cabling Type
1000Base-LX, 1000Base-LH
Data Transfer Rate
1.25 Gbps
Optical Wave Length
1310 nm
GigE
Max Transfer Distance
10 km
Cisco GLC-LH-SMD
0.9 cm x 6.5 cm x 1.4 cm
25 g
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Gb Fiber...
£73.75
