StarTech.com Gb MM SFP Fiber Transceiver
£47.74
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • StarTech.com SFP modules are backed by a lifetime warranty
  • Delivers reliable 1 GbE connections for 1000BASE-SX compliant networks
  • Hot-swappable with fiber-optic modules
  • Type: Transceiver
  • Stock Status: In Stock
Product codes
Add, replace or upgrade SFP modules on gigabit fiber equipment. The SFPSXMM Gigabit 850nm Multi Mode SFP Fiber Optical Transceiver - LC 550m is built to comply with MSA (Multi-Sourcing Agreement) standards to offer a cost-effective way to increase performance and connectivity of your fiber-connected network devices.
Using a short wavelength (850nm) VCSEL laser diode, enabling a maximum cable distance of 550m (0.3 miles) over multi mode fiber, this Small Form Factor Pluggable (SFP) Gigabit Multi Mode module can be installed into any fiber networking devices with an MSA compliant SFP port, providing a simple solution to upgrade existing network devices to connect to remote locations using LC terminated multimode fiber.
Delivering convenience and scalability, the optical transceiver allows you to install the multimode LC module without interrupting network traffic or requiring a device reboot.
Product Description StarTech.com MSA Uncoded SFP Module - 1000BASE-SX - 1GE Gigabit Ethernet SFP 1GbE Multi Mode Fiber (MMF) Optic Transceiver - 550m DDM - SFP (mini-GBIC) transceiver module - GigE
Device Type SFP (mini-GBIC) transceiver module - LC multi-mode
Form Factor Plug-in module
Cabling Type 1000Base-SX
Data Transfer Rate 1 Gbps
Optical Wave Length 850 nm
Data Link Protocol GigE
Max Transfer Distance 550 m
Dimensions (WxDxH) 1.3 cm x 5.5 cm x 0.9 cm
Weight 18 g
Designed For P/N: MCM1110SFP
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Gb MM SFP...
£47.74
