Add up to 10 different GbE devices to your network, using 8 RJ45 (PoE+) and 2 fiber-optic connections, with intelligent Layer 2 management. Easily deploy or scale your network with this Gigabit Ethernet switch, by adding eight copper Gigabit Ethernet ports (PoE+) and two fiber-optic SFP slots. This IP30 industrial network switch provides intelligent Layer 2 management. Its rugged, compact design and wall-mount option with front access
This versatile switch adapts to your network needs by providing two open SFP slots and eight RJ45 Ethernet ports (PoE+), providing both fiber and copper connections in a single network device. The MSA compliant SFP ports are compatible with 100/1000 Mbps networks. The network switch enables you to connect up to eight RJ45 PoE+ devices, so different users can share files and devices, such as printers and scanners, over a LAN connection.
Dual power input (terminal block and DC plug) provides flexible power options. The switch gives you the freedom to place your equipment in locations where power outlets are not available, with support for Power over Ethernet Plus. The network switch provides abundant PoE power, with up to 30 watts for each PoE port (200W budget).
Wall-mount the compact Gigabit switch to provide convenient front access to ports and indicators. It's ideal for a wide range of applications, including tight installation areas with significant electromagnetic interference, such as control cabinets and panels. The network switch is also DIN-rail mountable.
The switch delivers efficient and stable performance, with Layer 2 management capabilities. This lets you control packet traffic on a busy network, and customize your settings to achieve optimal network performance, offering improved efficiency and reliability.
This rugged network switch features an IP30-rated metal housing and extended temperature range of -40°C to 75°C, which makes it ideal for a wide range of operating conditions. The sturdy metal enclosure offers durability, even in harsh industrial environments.
With support for 10/100/1000Mbps transfer speeds, this managed switch supports full/half-duplex auto-negotiation, jumbo frames and auto MDI/MDIX operation. This lets you connect your network devices quickly and easily, with little to no configuration required.
Product Description | StarTech.com 8-Port PoE+ Gigabit Ethernet Switch plus 2 SFP Connections - Managed - Wall Mount with Front Access - switch - 10 ports - Managed | Device Type | Switch - 10 ports - Managed | Subtype | Gigabit Ethernet | Ports | 8 x 10/100/1000 (PoE+) + 2 x SFP | Power Over Ethernet (PoE) | PoE+ | PoE Budget | 200 W | Performance | Data transfer rate: 2 Gbps | Jumbo Frame Support | 9KB | Routing Protocol | IGMP, MLD | Remote Management Protocol | HTTP | Features | Flow control, Layer 2 switching, IPv6 support, full duplex mode, wall mountable, Trivial File Transfer Protocol (TFTP) support, tagged VLAN, 6KV ESD Protector, 802.1x authentication, Internet Control Message Protocol (ICMP), 6KV EFT protector | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at | Dimensions (WxDxH) | 14.8 cm x 13.4 cm x 2.5 cm | Weight | 496 g | Colour | Black | Manufacturer Warranty | 2-year warranty |
General | |
Enclosure Type | DIN rail mountable, wall-mountable |
Status Indicators | Power |
Expansion / Connectivity | |
Interfaces | 8 x 1000Base-TX RJ-45 PoE+ - 30 W , 2 x 1000Base-TX SFP , 1 x terminal block |
Miscellaneous | |
Colour | Black |
Included Accessories | 4 magnets, DIN-rail mounting kit, 4 x screws, 2 SFP dust caps, attaching pins, locking pins, 4 washers, 8 RJ45 dust caps |
MTBF | >100,000 hours |
Compliant Standards | FCC, RoHS, WEEE, IP30, RCM |
Dimensions & Weight | |
Width | 14.8 cm |
Depth | 13.4 cm |
Height | 2.5 cm |
Weight | 496 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | -40 °C |
Max Operating Temperature | 75 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
