StarTech.com Gel Keyboard Wrist Rest - Ergonomic - Black Fini...
StarTech.com Gel Keyboard Wrist Rest - Ergonomic - Black Finish -Non Slip
£13.17
38 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Ergonomic wrist support
  • Optimal comfort
  • Non-slip
  • Simple and sleek
  • Stock Status: In Stock
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £16.66
Save £1.50
Once you try this gel keyboard wrist rest, you'll wonder how you ever got along without it. It helps to keep your wrist supported as you use your keyboard, to reduce strain and enhance your comfort at work. It's the ideal ergonomic accessory.
Simply install the gel arm rest next to your keyboard for wrist support whenever you type. Use it on your desk, table, sit-stand workstation, or even laptop. As you type, the gel supports your wrist, providing comfort and slight cushioning. It's so light and comfortable, you'll hardly know it's there.
The innovative wrist cushion for keyboards features a modern design with a cushioned top surface that works like a wrist pillow. It gently cradles your wrist to provide support, helping to keep your hands in a neutral position while you type. The attractive black finish complements most workstations.
Product Description StarTech.com Foam Keyboard Wrist Rest - Ergonomic Wrist Support - Padded Keyboard Desk Cushion for Typing - Black Computer Hand & Arm Rest - keyboard wrist rest
Product Type Keyboard wrist rest
Dimensions (WxDxH) 46.1 cm
Weight 408 g
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Gel Keybo...
£13.17
