StarTech.com Gigabit Ethernet Fiber Media Converter Card Modu...
StarTech.com Gigabit Ethernet Fiber Media Converter Card Module with Open SFP Slot
£110.67
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Easily set up a full rack mount chassis of media converters with the card module design
  • Ensure maximum up-time with link-loss forwarding and remote status monitoring
  • Install the SFP of your choice with the open SFP slot
  • Type: Media Converter
  • Stock Status: In Stock
Product codes
Convert and extend a Gigabit Ethernet connection over fiber, using the Gigabit SFP of your choice. The ET91000SFP2C Open SFP Fiber Media Converter card module converts and extends a Gigabit Ethernet connection over fiber, using the Gigabit SFP of your choice.
A versatile solution for connecting an Ethernet (1000Base-T) network to remote network segments over a fiber backbone, the media converter features an open SFP slot that lets you choose the MSA-Compliant Gigabit SFP that best suits your fiber connection mode (single / multi-mode) and distance requirements.
Designed for applications where multiple chassis-powered media converters are required, this Gigabit media converter ships as a card module that can easily be installed into the 20 Slot, 2U Rackmount Chassis (ETCHS2U). For standalone operation this Gigabit media converter can also be purchased as a standard Open SFP Media Converter (ET91000SFP2).
The fiber to Ethernet converter offers simple plug-and-play installation, while support for full-duplex operation and Jumbo Frame support provides efficient network operation.
Product Description StarTech.com Gigabit Ethernet Fiber Media Converter Card Module w/ Open SFP - fibre media converter - GigE
Device Type Fibre media converter - RJ-45 / SFP (mini-GBIC)
Form Factor Plug-in module
Cabling Type 1000Base-TX
Data Transfer Rate 1.25 Gbps
Data Link Protocol GigE
Dimensions (WxDxH) 7.5 cm x 14 cm x 2 cm
Weight 100 g
Designed For P/N: ET10GSFP, GLCSXMMRGDST, J4858C10PKST, J4858CST
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Gigabit E...
£110.67
