StarTech.com Gigabit Ethernet Fiber Media Converter with Open...
StarTech.com Gigabit Ethernet Fiber Media Converter with Open SFP Slot
£119.29
Delivery:
Key features
  • Ensure maximum up-time with link-loss forwarding and remote status monitoring
  • Install the SFP of your choice with the open SFP slot
  • Operate as a standalone media converter or install into the ETCHS2U chassis
  • Type: Media Converter
Product codes
Convert and extend a Gigabit Ethernet connection over fiber using the Gigabit SFP of your choice. The ET91000SFP2 Open SFP Fiber Media Converter converts and extends a Gigabit Ethernet connection over fiber, using the Gigabit SFP of your choice.
A versatile solution for connecting an Ethernet (1000Base-T) network to remote network segments over a fiber backbone, the media converter features an open SFP slot that lets you choose the MSA-Compliant Gigabit SFP that best suits your fiber connection mode (single / multi-mode) and distance requirements.
The fiber to Ethernet converter has a durable all-steel chassis and offers simple plug-and-play installation, while support for full-duplex operation and Jumbo Frame support provides efficient network operation.
For added versatility, this Gigabit media converter supports standalone operation, or installation into the 20 Slot, 2U Rackmount Chassis (ETCHS2U). For applications where multiple chassis-mounted media converters are required, this Gigabit media converter can be purchased as a Card Module only (ET91000SFP2C).
Product Description StarTech.com Gigabit Ethernet Fiber Media Converter with Open SFP Slot - fibre media converter - 100Mb LAN, GigE
Device Type Fibre media converter - RJ-45 / SFP (mini-GBIC)
Form Factor External
Cabling Type 1000Base-SX, 100Base-LX, 1000Base-T
Data Transfer Rate 1.25 Gbps
Data Link Protocol 100Mb LAN, GigE
Dimensions (WxDxH) 9.5 cm x 2 cm x 16 cm
Weight 400 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Gigabit E...
£119.29
