StarTech.com Gigabit Ethernet Multi Mode Fiber Media Converte...
StarTech.com Gigabit Ethernet Multi Mode Fiber Media Converter SC 550m - 1000 Mbps
£138.27
27 in stock
Delivery:
Standard: 1-3 working days
Product codes
Convert and extend a Gigabit Ethernet connection up to 550 m / 1804 ft over Multi Mode SC fiber. The ET91000SC2 1000 Mbps Gigabit Multimode Fiber Media Converter (SC, 550m) lets you extend a Gigabit Ethernet network over multimode fiber, at distances up to 550m (1804 ft).
A cost-effective solution for connecting a Gigabit Ethernet (1000Base-T) network to remote network segments over a (1000Base-LX/SX) fiber backbone, the GbE to MM fiber converter supports full Gigabit speeds for ideal network performance and scalability. Designed to offer a durable and convenient Ethernet to fiber solution, this Ethernet to SC Fiber converter features an all-steel chassis, and a simple plug-and-play installation with minimal configuration required.
For added versatility, the fiber media converter supports standalone operation, or installation into the 20 Slot, 2U Rackmount Chassis (ETCHS2U).
Product Description StarTech.com Gigabit Ethernet MM Fiber Media Converter SC 550m - fibre media converter - GigE
Device Type Fibre media converter - RJ-45 / SC multi-mode
Form Factor External
Localisation North America, United Kingdom, Europe
Cabling Type 1000Base-LX, 1000Base-SX, 1000Base-T
Data Transfer Rate 1 Gbps
Optical Wave Length 850 nm
Data Link Protocol GigE
Max Transfer Distance 550 m
Power AC 120/230 V
Dimensions (WxDxH) 9.5 cm x 16 cm x 2 cm
Weight 0.62 kg
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Gigabit E...
£138.27
