StarTech.com Gigabit Ethernet Over Coaxial LAN Extender Recei...
StarTech.com Gigabit Ethernet Over Coaxial LAN Extender Receiver - 2.4 km
£170.22
Delivery:
Key features
  • Allows network connectivity in remote buildings made of stone/concrete, or heritage buildings where new Ethernet cabling or wireless are impossible
  • Simple plug and play installation for quick setup in your environment
  • Versatile point to point or point to multi-point allows long distance network extensions, or creation of local networks with many users
Product codes
Extend an Ethernet network over Coaxial cable up to 1.5 miles (2.4km) - Receiver only. The EOC1110R Gigabit Ethernet Over Coaxial LAN Extender Receiver (2.4km) is an additional receiver that can be used with the EOC1110K to create a point-to-multipoint topology, allowing you to span a Gigabit network over extremely long distances (up to 2.4 km) while still maintaining high speed network connectivity.
The device allows you to run the connection over existing coaxial cable with little to no modification required, making it a perfect solution for a broad range of applications, including connecting isolated user stations from within the same building or from a separate building, or overcoming infrastructure obstacles and distances (e.g. older stone/concrete architecture) where new wiring or wireless may be impossible.
When coupled with the EOC1110K Coaxial Ethernet Extender Kit, the Coaxial Ethernet LAN Extender Receiver helps to eliminate expense by allowing video streaming and data to share the same coax cable without interference.
StarTech.com Gigabit Ethernet Over Coaxial LAN Extender Receiver - short-haul modem - GigE
Short-haul modem - RJ-45 / F connector
External
North America, United Kingdom, Europe
Cabling Type
1000Base-T
Data Transfer Rate
112 Mbps
GigE
Max Transfer Distance
2.4 km
AC 100/230 V
28 cm x 13.9 cm x 7.7 cm
0.3 kg
2 years warranty
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Gigabit E...
£170.22
