StarTech.com Gigabit Ethernet over Coaxial Unmanaged Network...
StarTech.com Gigabit Ethernet over Coaxial Unmanaged Network Extender Kit - 2.4km
£285.75
Delivery:
Standard: 1-3 working days
  • Type: Media Converter
  • Stock Status: In Stock
Product codes
Extend an Ethernet network over Coaxial cable up to 1.5 miles (2.4km). The EOC1110K Gigabit Ethernet over Coaxial Unmanaged LAN Extender Kit (2.4km) includes both end points, and allows you to span a 10/100/1000Mbps Ethernet network over extremely long distances (up to 2.4 km/1.5 mi) while still maintaining high-speed network connectivity.
The coax Ethernet extender allows you to run the connection over existing coaxial cable, with little to no modification required, making it a perfect solution for a broad range of applications, including connecting isolated user stations from the same or separate building, or overcoming infrastructure obstacles and distances (e.g. older stone/concrete architecture) where new wiring or wireless connectivity may be impossible.
The gigabit Ethernet over coax kit helps to eliminate expense by allowing CCD or CATV video and Ethernet network data to share the same coaxial cable without interference.
Product Description StarTech.com Gigabit Ethernet over Network Extender Kit - 2.4km IP to Coax Converter - RJ45 LAN Ethernet to RG6 Coax Internet Adapter Kit (EOC1110K) - short-haul modem - GigE
Device Type Short-haul modem - RJ-45 / F connector
Form Factor External
Cabling Type 10Base-T, 100Base-TX, 1000Base-T, Coax
Data Link Protocol GigE
Max Transfer Distance 2.4 km
Power AC 120/230 V
Dimensions (WxDxH) 13.8 cm x 28 cm x 7.7 cm
Weight 300 g
Designed For P/N: EOC1110R, SVA12M2NEUA, SVA12M5NA
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Gigabit E...
£285.75
