StarTech.com Gigabit Ethernet Single Mode Fiber Media Convert...
StarTech.com Gigabit Ethernet Single Mode Fiber Media Converter SC 40 km - 1000 Mbps
£377.56
13 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Link loss forwarding, remote status monitoring help ensure maximum up-time
  • Provides Ethernet to Fiber conversion as a standalone device, or can be installed into the ETCHS2U 20 slot chassis for added versatility
  • Rugged steel casing for added durability in harsh environments
  • Type: Media Converter
  • Stock Status: In Stock
Product codes
Convert and extend a Gigabit Ethernet connection up to 24.8 miles/40 km over Single Mode SC fiber. The ET91000SM402 1000 Mbps Gigabit Single Mode Fiber Media Converter SC (40 km) lets you extend a Gigabit Ethernet network over single mode fiber by up to 40km (25 miles).
A cost-effective solution for connecting a Gigabit Ethernet (1000Base-T) network to remote network segments over a (1000Base-LX/SX) fiber backbone, the GbE to SM fiber converter supports full Gigabit speeds for ideal network performance and scalability. Designed to offer a durable and convenient Ethernet to fiber solution, the Ethernet to SC Fiber converter features an all-steel chassis, and a simple plug-and-play installation with minimal configuration required.
For added versatility, this fiber media converter supports standalone operation, or installation into the 20 Slot, 2U Rackmount Chassis (ETCHS2U).
Product Description StarTech.com Gigabit Ethernet Single Mode Fiber Media Converter SC 40 km - 1000 Mbps (ET91000SM402) - fibre media converter - GigE
Device Type Fibre media converter - RJ-45 / SC single-mode
Form Factor External
Localisation North America, United Kingdom, Europe
Cabling Type 1000Base-LX, 1000Base-SX, 1000Base-T
Data Transfer Rate 1 Gbps
Optical Wave Length 1310 nm
Data Link Protocol GigE
Max Transfer Distance 40 km
Power AC 120/230 V
Dimensions (WxDxH) 9.5 cm x 16 cm x 2 cm
Weight 0.6 kg
Designed For P/N: ETCHS2U, SVA12M2NEUA, SVA12M5NA
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Gigabit E...
£377.56
