StarTech.com Gooseneck Tablet Mount - 7-11"
£34.66
Delivery:
Standard: 1-3 working days
Key features
  • Fits most 7” to 11” tablets, with tablet width or length of 6.5" to 7.8” (166 to 200 mm) and max tablet thickness: 0.45" (11.5 mm)
  • Quickly adjust your tablet's viewing angle with this gooseneck tablet mount (with 19.7” 500 mm bendable arm)
  • Flexible gooseneck tablet holder turns, tilts and rotates 360 degree into landscape or portrait position
Product codes
Integrate your tablet into any workspace and adjust it to any viewing orientation or position. Add flexibility to your workspace, with this gooseneck tablet mount. Simply pop your Apple iPad, Samsung Galaxy, Microsoft Surface Pro 3 or 4, or other tablet into the stand, and position it at any angle for convenient, hands-free use. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
Now, you can put your tablet exactly where you need it, and position it to your preferred viewing angle. It's also easy to change from one position to another, giving you virtually limitless movement, and easily bending 360 degrees in any direction. The tablet holder tilts, turns and rotates, so you can switch from landscape to portrait position, and back again, instantly.
Use your tablet hands-free, while it's securely held in the tablet mount - an ideal solution for the office or home environment. At the office, integrate a tablet into your workstation for quick reference to enhance your productivity. You can also connect a Bluetooth keyboard for intensive typing work.
At home, watch movies or shows on your tablet with ease. Read e-books or check recipes without even having to hold your tablet. The freedom of using your tablet hands-free can also be helpful for individuals with mobility challenges, letting you easily re-position and use your tablet without having to hold onto it.
The gooseneck tablet stand is easy to mount on your desk, counter, tabletop or any other surface, with a thickness of 20 - 50 mm (.8 to 1.9 in.). The easy-to-use clamp (included) holds the stand securely in place.
The universal tablet mount fits tablets ranging in size from 7 in. to 11 in. (with a maximum tablet thickness of 11.5 mm). The tablet mount is also detachable with quick-swap attachments that let you remove the tablet from the stand, and pop it back in as needed.
StarTech.com Gooseneck Tablet Holder - For Most 7" to 11" Tablets - mounting kit
Mounting kit - desktop
Mounting Components
Clamp, adjustable holder, adjustable mounting arm
Rotation
360°
Adjustments
Height, pan, tilt
Recommended Use
Tablet
Recommended Display Size
7"-11"
Material
Plastic, steel
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Gooseneck...
£34.66
