StarTech.com HDMI capture device - USB video capture
£211.69
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Record video and audio to your Windows or Mac computer using this USB-C video capture device. This HDMI to USB-C video capture device lets you record HDMI video to your USB-C, USB-A or Thunderbolt 3 computer, and features a durable aluminum enclosure so it can safely travel with your laptop.
For hassle-free recording, you can install the HDMI capture device by simply connecting it to your computer. The capture device features USB Video Class (UVC), a video capture standard that's natively supported by Mac, Windows and Linux . Unlike other capture devices that require proprietary driver installation, UVC based capture devices install automatically for a truly plug-and-play solution. Also, with this capture device you're not limited to the included software. You can use any third-party software that uses UVC compatible frameworks such as Quicktime or DirectShow.
Record 1080p video at 60fps (frames per second), to save your content so it can be shared, stored, or edited. Capture meetings, presentations, conference calls and from security equipment directly to your computer.
Stream your video over the internet using Twitch or other third-party video streaming platforms. With the included software or your own third-party UVC compatible software like Open Broadcaster Software (OBS), you can live broadcast video over the internet using Twitch or other third-party video streaming platforms.
Product Description StarTech.com HDMI to USB-C Video Capture Device - UVC - 1080p - video capture adapter - USB 3.0
Device Type Video capture adapter
Interface Type USB 3.0
Dimensions (WxDxH) 6 cm x 9.2 cm x 2.3 cm
Weight 88 g
Colour Black, silver
Video Input HDMI input
Video Modes 1080/60p
Digital Video Format MPEG-4, H.264
Digital Video Capture Speed 60 frames per second
Digital Video Capture Resolution 1080p
Audio Input Support Standard
Features USB Video class
OS Required Apple MacOS, Linux, Android, Microsoft Windows 7 / 8 / 10
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com HDMI capt...
£211.69
