StarTech.com HDMI to Composite Converter with Audio
£131.90
Delivery:
Standard: 1-3 working days
Key features
  • Compact form factor and simple plug-and-play installation for fast, easy integration into your A/V environment
  • Support for multiple HDTV and PC input resolutions, providing compatibility with almost any source device
  • The ability to convert HDMI input to be used with legacy televisions adds flexibility and saves the cost of upgrading hardware
Product codes
Convert an HDMI? Signal with Supporting Audio to Work with Legacy Composite Video Televisions and Displays. The HD2VID HDMI? to Composite Video Converter (with Audio) converts a digital HDMI video source (with supporting audio) to work with analog Composite video televisions and displays in both NTSC and PAL systems. The HDMI to Composite converter provides features that ensure the highest quality output image, such as noise reduction, frame rate conversion and adaptive contrast enhancement, while an easy to use On-Screen Display (OSD) allows you to monitor your display status. Support for a wide range of HDTV and PC input resolutions make this versatile HDMI converter a perfect solution for using newer devices with existing legacy displays.
StarTech.com HDMI to Composite Converter with Audio - video converter - white
Video converter
Max Resolution
1280 x 800
1 x HDMI input - 19 pin HDMI Type A , 1 x composite video output - RCA , 1 x audio line-out - RCA x 2
11.4 cm x 6.5 cm x 2.6 cm
Enclosure Colour
White
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com HDMI to C...
£131.90
