This HDMI to RCA converter box with audio converts a digital HDMI video source (with supporting audio) to work with analog RCA composite video televisions and displays, in both NTSC and PAL systems.
This HDMI to composite video converter provides features that ensure the highest quality output image, such as noise reduction, frame rate conversion and adaptive contrast enhancement.
With support for high-definition input resolutions up to 1080p, this RCA adapter lets you convert your HDMI signal to composite video and audio while still producing a crystal-clear picture.
This lightweight composite adapter is compact and highly portable, so you can use it virtually anywhere. Offering support for a wide range of HDTV and PC input resolutions, this versatile RCA converter is a perfect solution for using newer devices with your existing legacy displays.
The ability to convert and use your new HDMI equipped device with your older televisions or displays not only offers flexibility but also saves you the cost of upgrading hardware, making it extremely convenient for home or office applications.
To ensure easy operation and installation, this unique RCA composite video converter allows for plug-and-play installation without any additional software or drivers.
Product Description | StarTech.com HDMI to RCA Converter Box with Audio - Composite Video Adapter - NTSC/PAL - 1080p (HD2VID2) - video converter - black | Device Type | Video converter | Interfaces | 1 x component video / audio input - RCA x 3 , 1 x HDMI output - 19 pin HDMI Type A | Dimensions (WxDxH) | 10.3 cm x 10.4 cm x 2.5 cm | Enclosure Colour | Black | Manufacturer Warranty | 2-year warranty |
General | |
Interfaces | 1 x component video / audio input - RCA x 3 - female , 1 x HDMI output - 19 pin HDMI Type A - female |
Video Input | |
Analogue Video Format | NTSC, PAL |
System Requirements | |
Voltage Required | AC 100 - 240 V / DC 5 V |
Miscellaneous | |
Included Accessories | Power adapter, 2 mounting brackets, 4 screws |
Compliant Standards | FCC, RoHS, WEEE, RCM |
Width | 10.3 cm |
Depth | 10.4 cm |
Height | 2.5 cm |
Weight | 225 g |
Shipping Weight | 300 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 90% |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
