StarTech.com HDMI to SDI Converter – HDMI to 3G SDI Adapter w...
StarTech.com HDMI to SDI Converter – HDMI to 3G SDI Adapter with Dual SDI Output
£180.16
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Connect an SDI Display to your HDMI Video Source. The HD2SDI HDMI to dual SDI converter enables you to turn your HDMI audio/video signal into two 3G SDI video outputs. The 3G SDI video outputs can then be individually extended up to 755ft (230m) over standard coaxial cable for large scale HD-SDI video distribution.
With dual SDI outputs, you can connect your HDMI video source to a local SDI display and output an additional SDI signal into your broadcasting equipment, providing a scalable solution for any SDI broadcasting application that requires an HDMI input.
To ensure you maintain perfect high-definition video quality, the HD-SDI converter supports resolutions up to 1080p, which lets you convert HDMI to SDI without sacrificing video quality.
For hassle-free installation, the HDMI to SDI converter offers a plug-and-play solution that includes pre-installed mounting brackets and requires no software or driver installation.
Product Description StarTech.com HDMI to SDI Converter - HDMI to 3G SDI Adapter with Dual SDI Output - HDMI to SDI Audio/Video Adapter - 755ft (230m) (HD2SDI) - video converter - black
Device Type Video converter
Max Resolution 1920 x 1200
Interfaces 1 x HDMI input - 19 pin HDMI Type A , 2 x 3G-SDI output - BNC
Dimensions (WxDxH) 10 cm x 7 cm x 2.5 cm
Enclosure Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com HDMI to S...
£180.16
