StarTech.com HDMI to VGA Adapter Converter for Desktop PC / L...
StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080
£25.74
42 in stock
Delivery:
Standard: 1-3 working days
Key features
  • The adapter features a simple, plug-and-play design ensures a quick and easy setup
  • The HDMI to VGA adapter doesn't require an external power adapter ensures maximum portability
  • High quality, compact design for long term durability and a minimal footprint
  • Stock Status: In Stock
Product codes
Connect an HDMI equipped laptop, ultrabook, or desktop computer to your VGA display, or projector. The HD2VGAE2 HDMI to VGA adapter allows you to connect an HDMI output from your laptop, ultrabook, or desktop computer onto a VGA monitor or projector, saving the cost of upgrading to an HDMI compatible display. Intended for outputting user generated content such as presentations, and work documents, the HDMI to VGA converter can also work to increase your productivity by extending your computer's desktop on to a secondary monitor, doubling available workspace. This active HDMI to VGA adapter offers a compact and portable solution for connecting a High-Definition VGA display.
Product Description StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 - video interface converter - HDMI / VGA - 24.5 cm
Cable High Speed video interface converter - HDMI / VGA
Max Output Resolution 1920 x 1080 - 60 Hz
Length 24.5 cm
Colour Black
Connector HDMI - male (input)
Connector (Second End) HD-15 (VGA) - female (output)
Features 1080p support, active adapter
Designed For P/N: DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK30CH2DEP, DK30CH2DEPUE, SV211HDUC
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com HDMI to V...
£25.74
