StarTech.com HDMI to VGA Video Adapter Converter with Audio -...
StarTech.com HDMI to VGA Video Adapter Converter with Audio - HD to VGA Monitor 1080p
£148.46
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Type: HDMI
  • Stock Status: In Stock
Product codes
Connect HDMI devices to a VGA monitor with stereo audio separation. The HDMI2VGA HDMI to VGA converter converts digital HDMI or DVI video signals to analog VGA, taking the input resolution from your device and converting it into an analog signal at the same resolution.
The converter also separates the audio stream from the HDMI signal (HDMI LPCM-2 Channel) and converts it to analog stereo audio that can be used with the VGA display.
With support for resolutions of up to 1080p, the HDMI2VGA converter is a perfect solution for connecting video cards (desktop or laptop) or consumer electronics devices such as game consoles or home theater receivers that offer an HDMI Out port to a VGA display.
The HDMI2VGA adapter/converter is simple to use, with no complicated settings.
Product Description StarTech.com HDMI to VGA Video Adapter Converter with Audio - video converter - black
Device Type Video converter
Max Resolution 1920 x 1200
Interfaces 1 x HDMI input - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x component video output - RCA x 3 (on supplied cable) , 1 x audio line-out - mini-phone stereo 3.5 mm
Dimensions (WxDxH) 7.6 cm x 7.6 cm x 9.2 cm
Enclosure Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com HDMI to V...
£148.46
